Multifunction DAQ
DAQmxErrChk(functionCall)
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error;
How do these 2 statements work in conjunction with the #define.
I am building on the example software for DAQmx Acq-IntClk.
I keep receiving the following compile error.
  118, 9   Undeclared identifier 'DAQmxErrChk'.
(7,903 Views)
Hi Rich,
Are you making the call "DAQmxErrChk(functionCall)"?  The call to DAQmxErrChk is looking for a function call as the parameter, and does not recognize the term "functionCall".  You mention that you are building on the example code; is the line of code that is returning the compile error an addition that you have made to it?  If so, verify that the parameter that you are passing is a valid DAQmx function.
Andrew W
(7,879 Views)
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
is the declaration of the Macro (as in the examples)
The first call
  // DAQmx Configure Code
  DAQmxErrChk (DAQmxErrChk = DAQmxCreateTask ("", &taskHandleAnalog2));
  DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandleAnalog2,chanAnalog2,"",min,max,DAQmx_Val_Volts,""));
produces this error   109, 9   Undeclared identifier 'DAQmxErrChk'.
When I check the project / Macros / DAQmxErrCheck is not listed
In the example code project / Macros / DAQmxErrChk is listed along with DAQmxFailed
I have searched for "How To Register" a macro, and can not find any information.
I have edited the Example Acq-IntClk.c and it performs my task very well.
We are using the USB-6008 in 7 locations. We needed to identify 2 special setups.
We jumpered the Analog I/O side to identify these setups.
I have "Cut & Pasted" the necessary code from the Example Acq-IntClk.c into our main code.
I am receiving the above mentioned error. Can you help ?
(7,871 Views)
Hi Rich,
It looks like the error is in the parameter you are passing to the first DAQmxErrChk call in the "DAQmx Configure Code" section.  The Acq-IntClk.c example has the first call as DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
Modify your first function call to
the following:
DAQmxErrChk (DAQmxCreateTask ("", &taskHandleAnalog2));
DAQmxErrChk is looking for any DAQmx function name as a parameter.
Andrew
(7,849 Views)
