Multifunction DAQ
DAQmxCreateAOVoltageChan error -200220
I want to send a signal on my NI USB-6009 using the NI-DAQmx C implementation. I want to sent a continuous signal and implement this function in Python 3. For this, I first tried the example of scipy cookbook, which I adapted
First I try to use the this example, but I always get the error -200220: 'Device identifier is invalid.' when calling DAQmxCreateAOVoltageChan, even though the device is listed as "Dev1" in Ni MAX.
(5,501 Views)
Accepted by topic author smiddy
I got the error on myself:
The error is the wrong assignment of the device: In Python 3, to hand over the physicalChannel property, the string has to be in bytes. Hence a quick fix to
        self.CHK(nidaq.DAQmxCreateAOVoltageChan( self.taskHandle,
                                   b"Dev1/ao0",
                                   float64(-10.0),
                                   float64(10.0),
                                   DAQmx_Val_Volts,
                                   None))
 solves the problem
(5,499 Views)
