Multifunction DAQ
DAQmx simulation
Hi all,
today I tested the new DAQmx version 7.4 and tried to use a simulated DAQ card. (For mobile develope I use a laptop without any external card.)
I programmed a small VI for data aquisition of analog inputs - that works with the simulated card and I got a sinus curve. Next I tried to do a pulse width measurement. The VI seemed to work without errors, but all datas are 0 (zero). A test in MAX showed the same result.
Is this reaction true, if I like to measure any frequency ore pulses wit a simulated device? The readme file described, to simulate all other functions of a card, like analog inputs, counters a.o.
Thanks for help,
Michael. Smiley Very Happy
(3,093 Views)
Thats the normal behaviour of this simulation. I get the same result (daqmx 8.0).
(3,065 Views)
