Multifunction DAQ
DAQmx read without waiting for buffer refill
I am using the continous acquisition mode and want to read at any time the 50 latest values out of the buffer without waiting for refilling.
I have found no setting to do this, the DAQmx read function is always waiting until the buffer is filled with the next 50 values.
Of course I could set the buffersize to 1 and read every single value, but that would be very time consuming.
Metin
(4,160 Views)
Hi MTNBZBG,
it is not possible to read the buffer without waiting for refilling.
If you have selected a buffersize of 50 do you have to wait for refill.
But you have the choice to use a Lossy Enqueue function.
So you have the chance to read just the last 50 elements out of the Queue.
http://forums.ni.com/t5/LabVIEW/When-to-use-lossy-Enqueue-Element-vs-Regular-Enqueue-non-lossy/td-p/...
(4,068 Views)
Correction, it definitely IS possible to do this, I've done it often.
See this thread for a snippet that shows how.
-Kevin P
(4,030 Views)
