Multifunction DAQ
DAQmx failure message
I am just working with LabView since 4 Weeks. I have a problem with a copy of Programm I am using on my own Computer. I tried to create a copy to work with it, so i want to avoid to transfer a mistake into the master programm. In the attachment i uploeded a screenshot of the error message. for help and advice I am deeply greetful.
Best Regards
(2,999 Views)
Just like the message says, the device identifier is invalid. You have to use the device that is installed on your system.
(2,980 Views)
I think you need to open Measurement and Automation Explorer (NI MAX) and rename your device currently names "Dev2" to "Dev1".
(2,978 Views)
