Multifunction DAQ
DAQmx Visual Basic 6
I am writing DAQ software for a NI DAQ card (E-series) using Visual Basic 6. I got stuck with statements (for example DAQmxCreateTask) not being recognised by Visual Basic 6. I used "nicaiu.dll" public declarations to get Visual Basic to recognise the statements as recommended by Bilal Durrani (NI Engineer) on the discussion forum on 12-07-04. (For example: Public Declare Function DAQmxCreateTask Lib "nicaiu.dll" (ByVal taskName As String, ByRef taskHandle As Long) As Long)
My problem is that some of the DAQmx functions from example software I have, calls for DAQmx parameters that are still not recognised by Visual Basic 6. For example: The statement DAQmxCreateAIVoltageChan(taskhandle, channel, "", DAQmx_Val_Cfg_Default, minVoltage, maxVoltage, DAQmx_Val_VoltageUnits2_Volts, vbNullString) does not recognise the parameters DAQmx_Val_Cfg_Default and DAQmx_Val_VoltageUnits2_Volts. The NI reference documentation only shows that the parameters have a 32 bit integer value but gives no indication what those values should be.
I will prefer not to use ActiveX controls if possible.
Any suggestions or sample code will be highly valued.
Gerhard Heymann
(3,565 Views)
Gerhard,
What version of NI-DAQmx do you have? With 7.5 and later, we supply a type library for use with VB6. We also supply examples in the
C:\Program Files\National Instruments\NI-DAQ\Examples\Visual Basic 6.0
directory. This support was added well after Bilal's post, so I would recommend going this route. Please post back if you still have trouble.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,550 Views)
Dear Ryan
I was using NI-DAQmx 7.1. On the basis of your recommendation I have now downloaded NI-DAQmx 8.1 from ni.com and my code is running beautifully!
Many thanks for your advice. It is much appreciated.
Best regards
Gerhard
(3,526 Views)
Gerhard,
Glad to help! No sense in reinventing the wheel.
Ryan Verret
Signal Generators
(3,523 Views)
