Multifunction DAQ
DAQmx Ubuntu
Hi
I have installed Labview 8.6 under Intrepid Ibex (8.10) Ubuntu distribution
and then I have downloaded the DAQmx driver (DAQmx801f0.iso) from the national site and saved in my computer directory
    max@skynet:~/Scrivania/Documenti/linux/DAQmx801f0$ ls -l
    totale 90748
    drwxr-xr-x 2 63005 63005     4096 2008-12-01 18:28 bin
    -rw-r--r-- 1 max   max      52388 2009-02-07 14:28 ConfigurationGuide.html
    -rw-r--r-- 1 max   max      99652 2009-02-07 14:28 INSTALL
    -rw-r--r-- 1 max   max      19588 2009-02-07 14:28 LICENSE.txt
    -rw-r--r-- 1 max   max   92551244 2009-02-07 14:28 nidaqmx-8.0.1f0.tar.gz
    -rw-r--r-- 1 max   max      14334 2009-02-07 14:28 PATENTS.txt
    -rw-r--r-- 1 max   max      33375 2009-02-07 14:28 README.txt
    drwxr-xr-x 2 63005 63005     4096 2008-12-01 18:28 rpms
    -rw-r--r-- 1 max   max      28073 2009-02-07 14:28 UNINSTALL
At beginnin I had not suppllied the RPM files and Ubuntu installed DAQmx without errors but in the in the "programming palette ----> measurament I/O" I had not found any new icones.
I have been supplied the RPM files:
    sudo apt-get install rpm
and I have re-installed the drivers
    max@skynet:~/Scrivania/Documenti/linux/DAQmx801f0$ sudo ./INSTALL
Ubuntu say me:
    Checking required install tools...
    Checking installer tool versions...
    rpm        4.4.2.3 can be used with a default installation path
    tar        1.20
    Checking dependencies...
    Warning: glibc was not found in the rpm database, but
         it appears to be installed on your system.
         This most likely means you are not using a RPM based
         Linux distribution, and need to manually populate your
         RPM database, or install with the --nodeps option.
Then I respond with:
    max@skynet:/media/cdrom$ sudo ./INSTALL --nodeps
and Ubuntu again:
    tar        1.20
    glibc      2.8.90
    Unpacking install files to /tmp/nidaqmx-8.0.1f0.install...
    Do you accept the license? [ynq] y
    LabVIEW 8.0 not detected
    Manually specify a location for LabVIEW 8.0 support files? [yN] n
    LabVIEW 8.2 not detected
    Manually specify a location for LabVIEW 8.2 support files? [yN] n
    LabVIEW 8.5 not detected
    Manually specify a location for LabVIEW 8.5 support files? [yN] n
    LabVIEW 8.6 detected in /usr/local/natinst/LabVIEW-8.6
    Install LabVIEW 8.6 support files? [Yn] y
    NI-DAQmx for Linux Installer Distribution version 8.0.1f0
    is about to be installed using rpm at /usr/local/natinst
    LabVIEW 8.0 support will be skipped.
    LabVIEW 8.2 support will be skipped.
    LabVIEW 8.5 support will be skipped.
    LabVIEW 8.6 support will be installed to /usr/local/natinst/LabVIEW-8.6
    Would you like to continue? [Yn] y
And the result is:
    Installing NI-DAQmx for Linux Installer Distribution version 8.0.1f0...
    Skipping nikali-1.9.0-f0.noarch.rpm installation, same or newer already installed.
    Skipping nipalki-2.3.0-f1.i386.rpm installation, same or newer already installed.
    Skipping nipali-2.3.0-f1.i386.rpm installation, same or newer already installed.
    Skipping labview80-rte-8.0-1.i386.rpm installation, same or newer already installed.
    Skipping ni653x-1.1.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nicdigi-1.5.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcapiexmp-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcapihelp-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcapii-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxcfgi-1.4.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxef-1.4.1-f3.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxhelp-1.0.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxinfi-8.0.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidaqmxswitch-1.6.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nidimi-1.9.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nidsai-1.5.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimdbgi-1.3.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimioi-1.7.2-f0.i386.rpm installation, same or newer already installed.
    Skipping nimru2i-2.4.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimxdfi-1.4.1-f1.i386.rpm installation, same or newer already installed.
    Skipping nimxpi-1.4.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nimxs-4.0.1-3006.i386.rpm installation, same or newer already installed.
    Skipping niorbi-1.9.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nipxirmi-1.6.0-f0.i386.rpm installation, same or newer already installed.
    Skipping nirpci-4.0.0-f1.i386.rpm installation, same or newer already installed.
    Skipping niscarabmm-1.2.1-f0.i386.rpm installation, same or newer already installed.
    Skipping niscxi-1.5.1-f0.i386.rpm installation, same or newer already installed.
    Skipping nistci-1.3.3-f0.i386.rpm installation, same or newer already installed.
    Skipping nitimingi-1.5.2-f0.i386.rpm installation, same or newer already installed.
    Pre Installation ...............................
    Post Installation ...............................
    errore: Dipendenze fallite:
        labview86-core necessita di lvsupport86-daqmxexmp-1.4.3-f0.i386
        /bin/sh necessita di lvsupport86-daqmxexmp-1.4.3-f0.i386
        labview86-core necessita di lvsupport86-daqmxsupp-1.4.3-f0.i386
        /bin/sh necessita di lvsupport86-daqmxsupp-1.4.3-f0.i386
        labview86-core necessita di lvsupport86-daqmxviref-1.0.1-f0.i386
        /bin/sh necessita di lvsupport86-daqmxviref-1.0.1-f0.i386
    Error installing NI-DAQmx for Linux Installer Distribution 8.0.1f0.
    Installer is aborted.
Please Note: In a precedent installation attempt Ubuntu, while it was installing the RPM files, said me twice there was a "bad loop for" and then it aborted the installer.
Are there any people that have already coped with this problem? (and maybe solved)
Thank you very much!
(6,143 Views)
Ubuntu is not officially supported as you can see at this link http://www.ni.com/linux/support.htm.
You might find something on NI forums and you can also take a look at www.lavag.org.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(6,127 Views)
