Multifunction DAQ
DAQmx .NET with C#: How to sync the signal with continuous reading
I am using C# with DAQmx .NET. I measure analog signal on one channel continuously.
My plan is to read 1024 samples and display it on the screen. If it work correctly, the signal should stay still if there is no change. However, the signal keeps scrolling on the screen.
If I use FiniteSamples, I can get the signal stay still but it is too slow.
Does anyone have any idea to solve this problem?
Thanks in advance.
(4,115 Views)
Itran,
What exact signal are you measuring? What device are you using to acquire this signal? What do you mean by the signal scrolling on the screen? Do you know what are the expected values? Could you please provide us with more detailed information? Thank you 🙂
William Fernandez
Applications Engineering
(4,076 Views)
