Multifunction DAQ
DAQmx Limiting device text box list to device "Dev1"
Hi, I have a problem with making text box list witch contain devices....
I fill text box list with function....
NIDAQmx_NewPhysChanAICtrl (panelHandle, PANEL_AIPHYSICAL, 1);
it 's ok, but next I want this list limit to device "Dev1" so I try use function....
NIDAQmx_SetPhysChanCtrlAttribute (panelHandle, PANEL_AIPHYSICAL, NIDAQmx_IOCtrl_Limit_Device, "Dev1");
but this function returns me error ....
FATAL RUN-TIME ERROR:   "BP1.c", line 54, col 70, thread id 0x00000DBC:   Missing argument to variable argument function.
I hope that my syntax is ok...
can you help me?
thank you for your request
(3,444 Views)
your question is not clear
mention
OS
NI software version
card number
as for as i understand , analog out task does not shows the analog in  channels like Daq Assistant
in labview 8. if you have installed 2 cards analog out , analog input. and u are configuring the input channels then output channels will not show.
(3,419 Views)
This issue is known and has been reported, there is however a work around; you can turn off run time error checking and the function will execute properly.
Options >> Build Options - Debugging Options >> Debugging Level = No run-time checking
I also believe that the correct method for implementing the function is as follows.
NIDAQmx_SetPhysChanCtrlAttribute (panelHandle, PANEL_AIPHYSICAL, NIDAQmx_IOCtrl_Limit_To_Device, 1); // Enables Limit
NIDAQmx_SetPhysChanCtrlAttribute (panelHandle, PANEL_AIPHYSICAL, NIDAQmx_IOCtrl_Limit_Device, "Dev1"); // Sets Limit
I hope this helps!!
JaceD
Signal Sources Product Support Engineer
(3,392 Views)
