Multifunction DAQ
DAQmx Error Code -89130: Device is not Available for Routing
I am using VC# with an PCI-6071e. I am using both traditional DAQ and DAQmx on the same system.
I am having trouble using DAQmx channels, specified in MAX. When I try to access/test the DAQmx channel, an error -89130 is generated.
I followed the instruction with the link below to reset both traditional DAQ and DAQmx.
DAQmx Error Code -89130: Device is not Available for Routing http://digital.ni.com/public.nsf/allkb/61371556441E5FF68625730600775934
The same error continues when re-running the application.
Any help is greatly appreciated.
Hui
(3,689 Views)
Hello Hui,
So are you able to see your device in Measurement and Automation Explorer?  Also, what version of DAQmx do you have?  Does your device pass a self-test in Measurement and Automation Explorer and, if so, what happens when you try running a test panel?
(3,671 Views)
