Multifunction DAQ
DAQmx E Series
  I am trying to read tc, voltage and current channels  in one task with a PC-MIO-16XE-50 Board and DAQmx 7.2, but the tc values are totally inaccurate and fluctuating. If I use just only  tc channels everything is good. What can I do? Is there a compatibility problem with PC-MIO-16XE-50 Board and DAQmx 7.2?.
(2,544 Views)
Two things
1. please attach the VI that you are using. Probably we could look  at it and suggest better
2. TC measurements need CJC. Are you providing any?
(2,535 Views)
