Multifunction DAQ
DAQmx DLL 25.8.45.49461 cannot be used in x64 application
I'm a software developer. I'm using vb.net programming language.
When I use the DAQmx DLL 25.8.45.49461in 64bit application, I got a system.Access.ViolationException.
With a 32bit application, the software is working.
Does anyone know a solution?
(85 Views)
Are you developing a .net core or .net framework application?
See the discussion in .NET DAQmx dll x64 assembly will throw system.AccessViolationException when calling DaqSystem.Local....
https://tmesystems.net/
(64 Views)
I'm using .net framework 4.8
I will check the linked discussion.
(54 Views)
