Multifunction DAQ
DAQmx Create Scale Unit
Hello!
I'm trying to "create scales" via importing from a configuration file.  Also importing physical channels, names, max, min, etc...
When I run the program in my Development Suite, everything runs fine.
Moving to the runtime machine, only the first scale is created correctly.
I'm adding pertinent files.
Thank you!
Development Suite LabVIEW 2012 V 12.0
Windows 7
NI-DAQmx 9.6
Runtime Machine:
Windows XP
Labview-runtime 2012
NI-DAQmx 9.6
(3,434 Views)
Apparently I didn't attach...
Actually, I won't let me...something about my attachment not matching it's file extension.
(3,433 Views)
Please save the VI in an older version.  Most people are not going to have LV2012.
(3,429 Views)
(3,427 Views)
Figured it out...had a couple pre-existing scales with the same name as the ones I was trying to create.  Smiley Frustrated
(3,419 Views)
