Multifunction DAQ
DAQmx AI read minimum number of samples
Hello all,
I'm reading an analogue input voltage in a while loop. I configured a sample clock (source = RTSI0 / mode = continuous samples) and a start trigger (digital edge). I have a problem When the sample rate on RTSI0 is very low and measure less than 2 samples each iteration. I can only read the buffer if it contains 2 samples! I'm missing the last sample when I generate an uneven number of samples (excluding the first trigger to start the task). How can I make sure I read all samples?
Jos
LabView 7.1
PCI-6220 card
(3,085 Views)
It looks like the driver optimized read out when you use the -1 as number of samples to read. When you ask for a fixed number of sample for example 3 then you will get 3 samples.
I'll look into this a bit further. If i find more information I'll update this thread.
Kind regards,
Karsten
(3,039 Views)
What is going on here is that in the DAQmx driver does 32bits transfers, this means that for 12 or 16 bit boards there will fit 2 samples in 32 bit. that is the reason why you always get a even number of samples. To get all samples per iteration you will have to use a second read function for 1 sample with a very low timeout. This will enable you to read the last sample in the buffer is there is one. you will get a timeout when there are none.
Hope this helps
Karsten
NI
(3,024 Views)
