Multifunction DAQ
DAQmx AI read at 2MS/s results in high CPU usage
I have an application that reads 32 channels of analog input signals at 2MS/s, simultaneously. The actual hardware will be: PXIe-8135 Win7, PXIe-1071 chassis, 2x PXIe-6368 (16 channels). The two PXIe-6368 will provide 32 channels data acquisition.
I don't have the hardware at this moment, but I've been estimating the CPU requirement on alternative set-ups, as I have concerns on CPU usage at high speed data acquisition. The two alternative set-ups are:
1) PXIe-8133 (quad core) WinXP, PXIe-1062Q, PXI-6133.
2) PXI-8106 (dual core) WinXP, PXI-1042, PXI-6133.
Note: PXI-6133 supports high speed AI at 2MS/s, simultaneously.
I've writen a simple continous data acquisition software to allow me to benchmark the CPU usage. The sampling rate and the number of channels are configurable. What I found is:
1) at low sampling rate, e.g. 100 kS/s, the CPU usage is minimal on both set-ups (dual core or quad core), no matter the number of channels is 1 or 8. The CPU reading was about 1-4%
2) at high sampling rate, e.g. 2MS/s, regardless of the number of channels being used, be it 1 or 8, the CPU usage was 50% for dual core, and 25% for the quad core, ie. a full core was fully used.
3) the transition from the low CPU usage (<5%) to high CPU usage (>45%) when the sampling rate increases is fairly steep and shows interesting channel-dependency (note the following was obtained with a dual core controller PXI-8106).
  • @1 channel, it happened between 950k to 970k,
  • @2 channels, it happened between 470k to 480k
  • @4 channels, it happened between 230k to 240k,
  • @8 channels, it happened between 120k to 130k,
This pattern reminds me of buffer length related issue but I double checked a sufficient length of buffer was used. It also suggests, some surprising congestion has happened when the amount of data increases to certain level.
My question is, is it a problem with this particular board (PXI-6133), or the DAQmx driver (9.5.5f4). How badly the problem is when I'm actually doing a 32-channel acquisition?
For your information, I've attached the benchmarking software.
Thanks!
Donghui Yin
(3,525 Views)
Just want to follow up ... Taskmgr showed that most of the CPU usage was kernel related. This means it has nothing to do with how I programmed the software; the bottleneck happened at the driver software or hardware level.
(3,516 Views)
Accepted by topic author doy
I followed this example code (see link below) and used event-based DAQmx, now the excessive CPU usage problem has been resolved. The CPU reading is now less than 10%, whereas it could be 50% (dual core case) or 25% (quad core case) at the same sampling rate and the number of channels.
http://zone.ni.com/devzone/cda/epd/p/id/5911
(3,474 Views)
