Multifunction DAQ
DAQ programming
I use Matlab to program. Can you tell me how to work on each Analog output channel individually. If you use putdata in matlab, you need to define the data for every channel. How to put data to one channel without caring about other channels? Thaks.
(2,562 Views)
Hello;
You are probably referring to the MATLAB DAQ toolkit. The best bet for you is to contact Mathworks to see if they have some example m files you can use.
Regards
Filipe A.
(2,562 Views)
