Multifunction DAQ
DAQ error possible capatability issue
Hello All,
I currently upgraded my work PC from Windows XP to Windows 7 now running Labview 8.5.  I currently have a NI PCI 6013 DAQ device, but when I run the main VI for acquisition I am getting no reading with an error.  I suspect that this device is either not supported in Labview 8.5 or Windows 7.  Besides upgrading is there any work around?
Thank you,
James
(2,737 Views)
James,
It doesn't seem like LabVIEW 8.5 is supported by Windows 7 so some of the functionality in LabVIEW may not work. You should also check which DAQmx/TraditionalDAQ drivers you are using to see if they are compatible as well. The only work around I could see is downgrading back down to Windows XP
LabVIEW and Microsoft Windows Compatibility
(2,698 Views)
