Multifunction DAQ
DAQ, capable to generate datastream 200Mbit/s
Is there a NI solition allowing to realize bistream generator with 200Mbit/s, or at least square waveform 200MHz ?
Preferably USB-based.
Thanks.
Pavel
(3,211 Views)
I think it is difficult assuming USB solution. Let's assume NI-9262.
This device has the fastest update rate in C-seried AO module.
The update rate is 1MS/sec. The data would be DBL (64bit) per one sample, you can update signal at 64Mbit/sec.
I think PXI can solve your problem. The fastest update rate at NI FGEN device is 800MS/sec.
Certified LabVIEW Developer
GCentral
(3,177 Views)
Hello Emboar,
Thank for suggestion.
PXI devices require chassis for connecting with host PC, isn't it ?
Or does exist some low-cost solution ... something like PXI-USB bridge ?
Thanks.
(3,168 Views)
Yes, PXI chassis is required but, i believe you must ask NI directly.
I think DF isn't suitable to ask a question related to product selection.
I think Thunderbolt is one of low-cost solution.
http://www.ni.com/white-paper/53757/en/
GCentral
(3,159 Views)
