Multifunction DAQ
DAQ X Series timer interrupt
I have a DAQ X Series PCIe 6363 board and trying to implement such scenario with C++:
- Setting the timer of the board to 1 ms
- For each 1 ms, the  board should trigger an interrupt to a thread that will do some real time task for me.
I am very new to data acquision topic, so I could not reach any information about implementing such scenario. Sory if this is the wrong location.
Thanks in advance for your support.
(3,840 Views)
Hi masln,
I would recommend looking through the examples for DAQmx. I'm assuming you're programming this through Measurement Studio. You can find the examples on your computer by following this KB:
Where are NI DAQmx Examples Installed?
https://www.ni.com/en/support/documentation/supplemental/18/ni-daqmx-example-locations-for-labview-a...
You can also look through the community examples posted on ni.com: https://forums.ni.com/t5/Example-Programs/ct-p/code-documents
Please let me know if you're still unable to find any example code!
aprillest
(3,810 Views)
