Multifunction DAQ
DAQ Timing
Hello, I have a DAQ Assistant , 4 signal collectors and one Write to Meas File placed in a while loop. The DAQ Assistant is set to aquire 1 sample(on demand) and i need to have 2 samples per second. So when i have a timer to wait 500 ms i get one sample every 2 seconds instead  of 2 samples per second. Why is that and how i can get perfect match between time column and no of samples in the file i obtain?
Thanks in advance!
(4,217 Views)
With on demand timing, you are using software timed operations and with the Write to Measurement File, you are using a slow method. Set the DAQmx timing for your rate and use N samples in continuous mode. You should use a producer/consumer architecture if you stick with Write to Measurement File. Or, use the lower level DAQmx functions and tdms streaming.
(4,206 Views)
Should i let' s say set to 4 samples to read with 8Hz in order to get 2 samples Per second?
(4,202 Views)
A sample rate of 8Hz means 8 samples per second. If you specify 4 samples, it will acquire those in half a second. This is basic arithmetic.
(4,195 Views)
