Multifunction DAQ
DAQ System Needed
Hello!
I'm getting started on a couple systems we need for testing and I'd like some hardware ideas to pursue.
System A:  8 Analog DI inputs measured at 25kHz + 5 PWM inputs + 6 CAN readings.
System B:  1 Analog DI input measured at 25kHz + 4 PWM inputs + 3 CAN readings.
Suggestions would be greatly appreciated!
Thanks!
(2,816 Views)
Hi Oley,
Can you please provide more information about the devices you are looking for? Also, can you please what you mean by 6 CAN readings?
Please refer to the following links for choosing the right CAN and DAQ card for your application.
DAQ
CAN
Thank you,
Simran K
(2,793 Views)
