Multifunction DAQ
DAQ Solution Wizard greyed out in Labview 5.1
My DAQ board seems to be work correctly when using MAX, but in LabView the DAQ Solutions Wizard is greyed out. I have a PCI-MIO-16E-4 DAQ board, Labview v5.1 and NI-DAQ v6.9.2f8. I am running Windows 2000.
(2,938 Views)
Make sure that the LabVIEW 5.1 support files have been installed along with NI-DAQ. Go to the Control Panel >> Add/Remove Programs >> NI-DAQ >> click Change >> select Add/Remove. If there is a red X next to LabVIEW 5.1 support, then it has not been installed. Install the entire feature and the DAQ Solutions Wizard should work.
(2,938 Views)
I checked whether or not the LabVIEW 5.1 support was installed and it already was. Does anyone have other ideas why the DAQ card does not work with LabVIEW?
(2,938 Views)
