Multifunction DAQ
DAQ_Op conversion
In my DAQ (6013) application I, read data using DAQ_Op()
Currently I reimplemented it using DAQmx.
I have created a analog voltage channel and read data using DAQmxReadAnalogF6.
But I am not getting the same data  as in DAQ_Op (under same environment), the value is in a lower range.
What is wrong with DAQmx in analog data reading?
(3,131 Views)
Accepted by topic author praveenda@gmail.com
I understood!
Wrong to use F64 to read data. DAQ_Op returns short integer, so use any integer returning read function like i16 etc
(3,100 Views)
