Multifunction DAQ
DAQ Error
Why do I have this error when running the same program
in one PC but no error in another? 2 PCs have the same
setup, hardware, channel config and all. Please help
Error: "A channel, port or counter is out of range
for the device type or device configuration; or the
combination of channels is not allowed; or the scan
order must be reversed (0 last)."
(2,482 Views)
Greetings,
What hardware are you using? Which VI is returning this error? Which channels on the hardware are you attempting to access? What syntax are you using?
Spencer S.
(2,482 Views)
