Multifunction DAQ
DAQ Error -200284
I am using a USB 6009 DAQ device and am trying to continuously acquire samples from 4 analog input channels. I am getting a strange intermittant error:
Error Code: -200284
NIDAQ Data Acquisition RevD.vi<append>
<B>Property: </B>RelativeTo
<B>Corresponding Value: </B>Current Read Position
<B>Property: </B>Offset
<B>Corresponding Value: </B>0
<B>Task Name: </B>Data Acquisition
I am using a simple VI in Labview consisting of a slightly modified continuously sampling DAQ assistant inside of a while loop.
The error will only occur sometimes when the VI is started and once it starts without error it will continue to run without any issues.
(4,159 Views)
Hi littleowl960,
  1. Check out this forum post. It seems pretty similar to yours. It essentially says you are receiving a timeout error and should increase your timeout value or acquisition rate, or decrease your buffer size.
  2. Check out this KnowledgeBase article about this error.
  3. If you could post your code we may be able to direct you even further on what is causing this issue.
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
(4,122 Views)
