Multifunction DAQ
DAQ Card PCMCIA DAQ 700 not detected in MAX
hi,
not able to detect the Hardware DAQ 700 PCMCIA card in MAX
however the device is detected in the windows 2000 ' device manager ' under Data Acquisition Devices as DAQ Card 700.
Also have downloaded the driver software for the same version 6.9.3 but still no use
please let us know as soon as possible
bye.
(3,928 Views)
here,
Are there any warnings in the Device Manager (yellow exclamation points?) Is there a resource conflict? It may be helpful to call into NI technical support at 1-800-IEEE-488 to troubleshoot this issue with someone over the phone.
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,909 Views)
Thankyou so much
well actually what had happend is we were installing the version 6.9.3 drivers over the NI Daq Legacy device drivers Verion 7.1. Hence we were to able to detect in max
now the only thing we need to know is if it is possible to have a patch for using this NI 700 daq card in Labview version 7.1
(3,882 Views)
here,
It is possible to use NI-DAQ 6.9.3 with versions of LabVIEW greater than 6.1. Please let me know if you have any questions on it.
Hope this helps,
Ryan Verret
Signal Generators
(3,867 Views)
will try this and then let you know
hope it should work
bye
naru
(3,850 Views)
