Multifunction DAQ
DAQ Assistant error
Hi everyone!
In my labview 8.5 version, it doesn't have DAQ Solution Wizards...Maybe I missed something while setting up sofwares....Please give me some advice !
Thank you so much!
Message 11 of 17
(2,164 Views)
What do you mean by DAQ Solution Wizards? The DAQ Assistant is installed by insyalling the DAQmx driver. Did you do that? What version?
Message 12 of 17
(2,160 Views)
I am not sure about DAQ solution wizards...because I need it to complete a tutorial in the basic cause in Labview version 8.5
Message 13 of 17
(2,157 Views)
Your tutorial is very, very out of date. There has not been a DAQ Solution Wizard in this century, I think.
Message 14 of 17
(2,154 Views)
Hi Joja,
The answers to your questions regarding the DAQ Solution Wizard can be found here: where is DAQ solution Wizard in LABVIEW8 . That forum discusses the update away from the DAQ Solution Wizard and has links to tutorials on using DAQ Assistant and the DAQmx drivers.
I hope that helps!
Matt
NI Community Team
Message 15 of 17
(2,138 Views)
Thanks Matt !
I got it. Now I have another card interface (is not supported by NI company, it is made by my teacher ). It did not appear on MAX and I don't know how to connect with it...Please help me!
Message 16 of 17
(2,134 Views)
Hi JoJa,
This may be a number of various factors such as what type of card it is and how it is expecting to be communicated to. It may also require a device driver in order to communicate with MAX and other software programs. I would recommend checking with your teacher on whether he/she has developed a driver to communicate with this card or if it uses some standard communication protocol.
I would also recommend creating a new Discussion Forum thread for this issue or searching for an existing thread that is related. This issue is not related to DAQ Assistant and you will likely get more help and more interested parties looking at your post if you create a new thread or post to a more closely related one.
Matt
NI Community Team
Message 17 of 17
(2,124 Views)
