Multifunction DAQ
DAQ Analog Input PXI 6229
I have a problem with my PXI system.
I´m using the pxi card 6229. The digital and analog output ist working.
But I´m need  the analog input, too.
If there is no connection to the inputs, the value is changed to undefined values.
If I connect a defined voltage (e.g. from an power supply unit) the input value is changed again.
Is there any configuration to change? The adapter tbx-68 is in the MAX configuration.
Thanks for help.
(3,094 Views)
Could you please be a little more clearer regarding the problem??
If you connect a suitable signal to the DAQ AI channels, is it read correctly??
Message Edited by devchander on 10-19-2007 08:06 AM
(3,086 Views)
