Multifunction DAQ
DAQ_6323 card Open Collector
Hello Gang
I'm creating an ATE for our PCB's with C# and require some clarification on the DAQ_6323 (NI PCIe-6323) output configuration to OPEN COLLECTOR (or OPEN DRAIN) can this card's IO be configured with is output type?
If so can you point me to a C# example ?
Many thanks AA
(628 Views)
Accepted by topic author DoubleHey
No, the digital outputs of NI 6323 are NOT open-collector and are push-pull type. If you need open collector, you need to add external circuit to make the push-pull into open-collector
Santhosh
Soliton Technologies
(626 Views)
Thanks Santo_13,
I was looking in the datasheet and didn't see it.
(624 Views)
