Multifunction DAQ
Controlling an AC heater ban with analog output instead of PWM
I'm up against a problem.  I ordered an NI USB-6009 low-cost multifunctional DAQ and it doesn't have all the "multifunctional" I need.  Apparently, this thing has a counter that counts but doesn't do pulse train generation like my other multifunctional daq devices have.  However, I do have 2 analog outputs.  Any ideas on what I would need to either convert my analog output into a TTL PWM signal?  I've always controlled my heater bans using an AC relay controlled via PWM that is set by a software PID controller using a thermocouple as feedback.  I'm not familiar with what hardware I would need to use in order to take advantage of the analog outputs.
(3,942 Views)
What frequency do you want to run your PWM signal at?  The AO only runs at 150 Hz.
Message Edited by rpursley8 on 05-29-2008 03:26 PM
Randall Pursley
(3,931 Views)
Hmm....  I guess I did not consider the possibility of generating a PWM signal out of the analog output.  I want to output 0-10V and then have some sort of converting hardware that would translate that into a PWM with some low frequency pulse-width (on the magnitude of 2-5hz for the width of the pulses).  So for instance, 5V into my device would produce a 50% duty cycle, and likewise 10V would produce a 100% duty cycle.  But if I want to make code to generate a PWM signal, why not just use on of my digital outs then?
The problem with PWM a digital output pin is that my software is responsible for the timing and that will be an extra load on the CPU.  I suppose if it were slow enough (say a 2hz pulse width) it wouldn't make that big of a difference.  I do prefer, however, passing the duty cycle and pulse width frequency to a counter and let the hardware do all the work w/o excess interruption to the CPU.
Hmmmm.......
(3,924 Views)
You can set up the AO channels to update at 2-5 Hz.  One channel would generate a ramp signal (0-10 V).  The other signal would be your control signal.
You could then run both channels into a comparator to create your PWM signal.
Attached is a suggestion.
Randall Pursley
(3,910 Views)
Here is one where you just output the PWM signal directly updating at 5 Hz.  It shouldn't take up too much PC resources since you are only updating the DAQ card 5 times a second.
Randall Pursley
(3,882 Views)
Hi!
Thanks!  That will work well!  I was going to make a circuit using opamps to make a sawtooth and then run the voltage through a comparitor.
-Nic
(3,878 Views)
I did make a mistake.  The sampling rate has to be set at 150 Hz for the USB-6009 and the ramp can only have 75 levels at a 2 Hz PWM.
Randall Pursley
(3,876 Views)
