Multifunction DAQ
Controlling NI USB-6501 via MATLAB & Data Aquisition Toolbox
I'm working on a project in which I need to control a valve from a computer (open/close). Due to my university's lack of a LabView license, I'm attempting to control the control signal using a NI USB-6501 DAQ and MATLAB.
The NI USB-6501 did come with a CD which I believe has NI-DAQmx software that I can install. My university also has a license for DAQ Toolbox.
Should I be able to throw a combination of these together to control my valve? I'm just trying to get some insight before I go trying things. I have very limited experience with LabView/DAQ's, and a few years of basic programming experience with MATLAB.
Thanks for any input!
Zack
(5,086 Views)
I was able to see my DAQ using the following MATLAB command:
daq.getDevices
Does anybody have any experience with the coding? I'm trying to generate a 5V output signal.
(5,033 Views)
Matlab is not an NI product and its not supported here. You should be asking Mathworks about their software.
You can test the functionality of the device in Measurement and Automation Explorer. You should also be able to get the student edition of LabVIEW for free. http://www.ni.com/labviewse/
(5,029 Views)
If you need more than the six months, buy the student license at Studica for the whole $20.  Either way, that will come with examples in LabVIEW you can use to skip the frustration of using matlab to get the functionality.
(5,023 Views)
Thanks to both of you, I appreciate the help!
(4,996 Views)
