05-17-2006 06:55 PM
05-23-2006 12:43 PM
Ryan
Thank you very much, sending me this way to do my block diagram in LabVIEW 7.1 and DAQmx PCI 6221.
I am goint to try to do this.
Regards.
Sidney Nogueira
07-03-2006 02:40 PM
Please I am not understanding why I configure the x - axis ( time ) between 0 to 15 seconds ( for example ) into one Waveform Chart, and when I run the program this values changes with big numbers differents than that I used according above described.
I am using the LabVIEW 7.1, one DAQmx model PCI 6221 and my diagram is only one DAQ Assistant reading the nine channel ( AI9 ), where the range in y - axis is voltage configureted from 0 to 10 Vcc, and acquiring data contiinuously with 500 samples at 1000 Hz.
I used one while Loop and 100 ms for each iteration. To stop I have one button.
Sidney Nogueira
07-11-2006 02:06 PM - edited 07-11-2006 02:06 PM
Hello
Thank you for posting to the NI Discussion Forums. I apologize, but I do not quite understand the question you are asking. It sounds to me like you have a waveform chart, and are typing in a time interval of 15 seconds in the X axis, and when you run your program the axis changes its time scale. If this is the case, I suspect that the problem lies in the X-Axis auto-scaling. Have you configured the axis to auto-scale the x-axis? You can set this option by right-clicking on the chart and choosing “properties” (see below).
I hope this helps! Please let us know if you have any additional questions.
Message Edited by Travis M. on 07-11-2006 02:06 PM
