Multifunction DAQ
Continuous DAQmx GetData method returns data with glitch offset
I use MeasurementStudio ofr VisualStudio.NET 2008 to collect a continuous acquisition at 20kHz (NI-6009).  I use the DAQ assistant to create a task that returns the data every 500ms.  I use GetData to return a waveform.  But every time I plot the trace, there is a 0.15V offset for the first very milliseconds, then the data is correct. It looks like noise, but if I speed up or slow down the acquisition, the "glitch" always follows the beginning of the returned data (from GetData method). I attached some pictures.
Here is the code from the DataReady Event
    Private Sub AD_DataReady(ByVal sender As Object, ByVal e As DaqTaskComponentDataReadyEventArgs) Handles AD.DataReady
        Dim d() As NationalInstruments.AnalogWaveform(Of Double)
        d = e.GetData()
        Me.WaveformGraph1.Plots(0).PlotWaveformAppend(d(0))
        Me.WaveformGraph1.Plots(1).PlotWaveformAppend(d(1))
    End Sub
(4,525 Views)
Hey dualtronic,
Are you seeing the same "glitch" when you try running our DAQmx VB.NET examples? If you are creating a task in Measurement and Automation Explorer (MAX) and then using that task within your code, then the GlobalContinuousAI_USB example (which can be used for non-USB devices) should show the same behavior. You can find this example here: C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS2008\DotNET\Examples\DAQmxWithUI\GlobalContinuousAI_USB\vb
Try running this and see if the glitch still appears and if there are any noticable differences between your code and this example.
Lars
(4,478 Views)
Hello Lars,
I tested the example application. It does NOT have the glitch. However, the example is hand-coded and does not use the Measurement Studio DAQ Assistant.  Under the surface, the DAQ assistant auto-code uses a more complex data handling mechanism.  I attached the project that shows the glitch. The only code I added is the DataReady event to display the data on a graph.  You will need to have some type of ramping input voltage to see the glitch (otherwise it looks like noise).  I believe that the data is being transposed somehow. The data at the end of the timespan is being put at the beginning, thereby showing up as a glitch in the signal.
Joe
(4,464 Views)
Hi Joe,
I've been fiddling around with the auto-generated code for the DAQ Assistant (this nice thing with the DAQ Assistant is that it gives you all the code that it auto-generates, in a .cs/.vb file with the same name as the .mxb file and you can play around and tinker with it), and I believe I found out what is causing this...
If you look at the auto-generated code in your project (it is titled DAQTask1.vb), there is a line in there that actually starts the DAQ Read:
Reader.BeginMemoryOptimizedReadWaveform(DefaultNumberOfSamplesToRead, callback, state, data)
Change this to:
Reader.BeginReadWaveform(DefaultNumberOfSamplesToRead, callback, state)
and it should work....
It seems that there was some bug with the memory optimized read, I will be filing a bug report with our R&D department to root cause the issue.
Also, FYI, I personally add an event handled for the Closing event of the form and put the following line in there:
daqTaskComponent1.StopRead();
Doing this, you don't have to manually stop your task using the button/switch before closing your app!
Hopefully this should get you up and running for now! Let me know if you have any follow up questions.
Jervin Justin
NI TestStand Product Manager
(4,343 Views)
Thank you Jervin!  I was forced to abandon the DAQ Assistant for a long time. Now I can start using it again. Hopefully this bug will be resolved in the next NI-DAQ release.
-Joe Labataille
(4,316 Views)
