Multifunction DAQ
ContWriteDigChan_Burst example throws and exception.
When I try to run the ContWriteDigChan_Burst example I get the following message from an exception trying to call this function "ConfigureHandshakingBurstExportClock":
"Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.\n\n
Property: NationalInstruments.DAQmx.Timing.SampleTimingType\n
Requested Value: NationalInstruments.DAQmx.SampleTimingType.BurstHandshake\n
Possible Values: NationalInstruments.DAQmx.SampleTimingType.OnDemand\n\n
Task Name: _unnamedTask<0>\n\nStatus Code: -200077"
How can I solve this problem?
Thanks in advance,
Dolev.
Message 1 of 1
(1,162 Views)
