Multifunction DAQ
Cont Read Dig with DAQ6062E
I tried to execute the example "Cont Read Dig Chan-Ext Clk.vi" with the DAQ6062E PCMCIA. But it failled with the error -200077. When I run the example with the PXI6115, it works.
Where is the difference in the DAQ Cards?
Christoph
(3,161 Views)
Hi Christoph-
Your PXI-6115 (and some other S Series and most M Series devices) supports hardware-timed "correlated" digital I/O.  E Series devices such as your DAQcard-6062E do not.  So, you'll receive an error if you attempt to run that example with a device that does not support clocked digital operations.
Hopefully this helps-
Tom W
(3,140 Views)
