Multifunction DAQ
Connecting and Controlling micro servo sg90 using PCI-6259 DAQ connected to BNC-2110 board
Hi everyone,
I have a PCI-6259 daq connected to BNC-2110 board and a sg90 servo motor. I would like to connect the servo to the BNC-2110 board and control it using labview. In one attempt, I connected the ground(brown) and Vcc(red) wires of the servo to +5 and D GND pins on the BNC-2110 board in the digital and timing I/O; see attached picture. Moreover, I connected the PWM(orange) wire of the servo to ctr01 pin (PF13/P2.5 pin in the picture). Then I used the labview program attached(Servo111) below to control the servo by changing the duty cycle knob. The programs runs but when I change the duty cycle the motor does not rotate at all. Any Idea what I did wrong or what I am missing?
Big Thanks in advance!
(2,746 Views)
Can you provide an image of you actual hardware setup?
(2,715 Views)
Here is the picture!
Thanks alot.
(2,710 Views)
