Multifunction DAQ
Connecting analog input signal to SCB-68
Kindly provide me basic connection of a single analog input (signal generator) to SCB-68 connector block. the block is connected with DAC_AI_16E_4(Laptop PCMCIA). Do it need any external power source as mentioned +5V in the pindiagram? What is the minimum requirement of connection to simply test the analog data aquisition. I am asking it from a level of beginners. Kindly answer it which can easily applicable to start the DAQ application.
Rajesh Patel,
Research Scholar
IIT Roorkee (INDIA)
(4,795 Views)
Please take a look at the product manual for the SCB-68, which can be found at http://www.ni.com/pdf/manuals/320745b.pdf. If you look at page 1.8, you'll find the SCB-68 I/O Connector Pinout, which shows you the Analog pin numbers you can use to connect your signal to (i.e. ACH0 - ACH15, and the AIGND's). Then if you take a look at page 3.1 through 3.10 of the manual, it explains how to connect your analog input signal to the SCB-68. If you are connecting a signal generator to the SCB-68, you'll probably want to use the grounded signal source type of connection, but make sure you reference Figure 3-1 to understand how to hook up your particular analog signal.
If you take a look at Appendix A-1 in the manual, it explains the power requirements. Most of the
time, the SCB-68 does not need any external power source because it is powered by the host computer, but your setup might need the external power supply.
The minimum requirement of connections is that you need some sort of analog input signal connected to the SCB-68. Connect the SCB-68 to the DAQCard-AI-16E-4. Open up the Measurement and Automation Explorer, which should have come with the software cd. Click on Devices and Interfaces, and find your card under there or under Traditional NI-DAQ Devices. Right click on your card and select Test Panels. This is where you can see your analog input signal. This is the simplest way to test the analog data, without using any software, such as LabVIEW. If you want to actually store the data, or do something with it, you'll have to use the software that allows you to do this.
Finally, you can find a lot of helpful information on the National Instruments web site under the Support section, especially in the Knowledgebases, Example Code, and
the Installation and Getting Started sections.
(4,795 Views)
If you take a look at Appendix A-1 in the manual, it explains the power requirements. Most of the time
Finally, you can find a lot of helpful information on the National Instruments web site under the Support section, especially in the Knowledgebases, Example Code, and the
DJ Loberg
(4,795 Views)
hai i am Manick...new to Labview.... in my working project.... i have PCI7830Rcard... and i have connector Block SCB68.... now i want to map this two.... tell me the way of connecting Anolog output signals of card to SCB68....i created a DAQmx VI ..i want to know how could i map this both in hardware and  in VI ????
(3,783 Views)
