Multifunction DAQ
Compilation problems using NI-DAQmx with Visual Basic
I recently have been using Visual Basic 2005 to implement NI-DAQmx. However, when attempting to debug the program once I've added references to NationalInstruments.Common and NationalInstruments.DAQmx, I keep getting warnings stating that the program has 'Found conflicts between different versions of the same dependent assembly.' Typically, when I allow VB to resolve this conflict on its own, it works; however, in this case the conflict continues to occur. This is not necessarily a new problem on this machine: I also get this error when trying to run the NI-DAQmx example vbproj file WriteDigChan.2005. Also, this error seems to occur only a one machine; it does not occur on another machine, but it occurs on the machine that we need.
Any help? Is this simply a question of reinstalling NI-DAQmx on this box?
akloth
(2,938 Views)
Hi akloth,
Please look at the following knowledge base and let us know if you need any more help/information. I think this knowledge base addresses your issue.
http://digital.ni.com/public.nsf/allkb/17146CC2A32D47338625712D005E4CC8?OpenDocument
Canisius
(2,919 Views)
