Multifunction DAQ
Compatible start triggers and timing types for a PXIe-6535?
What are the supported Start Trigger Type and Timing Type combinations on the PXIe-6535 in the DAQmx .NET API?  I keep getting DAQmx exceptions complaining about the Start Trigger Type requested is not supported given the requested Timing Type.
(3,662 Views)
Did you check the manual?
http://www.ni.com/pdf/manuals/374373g.pdf
(3,657 Views)
