Multifunction DAQ
CompactDAQ modules compatibilty
I am using CompactDAQ chassis cDAQ-9178.
the modules in questions are ni-9411 (digital input) and ni-9219 (AI).
Both modules working fine if i used them separately, but the problem appears when i try to use them together on the same chassis.
are both modules can be used in the same chassis ?
i tried to use two daq assistant for each on the same vi, is that legal?
(1,178 Views)
It should be okay to use both modules simultaneously and in two different DAQmx tasks.
I recommend using the DAQmx VIs, instead of the DAQ Assistant, but either approach should work having two of them in the same VI: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
(1,112 Views)
