Multifunction DAQ
Communicat​ing with EEPROM through I2C protocol using DAQ 6229
I'm developing code to write and read one byte operation with EEPROM using PCI 6229 DAQ. Problem is  written and read byte is not matching. Attached the code for the reference.
Appreciate ur help..
(2,924 Views)
M series DAQ doesn't support I2C communication.
You should use HSDIO 655x or NI 8451 for the application.
Thanks!
NI China
AE
Bobby Sun
(2,849 Views)
You  can see the article for reference.
http://zone.ni.com/devzone/cda/epd/p/id/6200
Thanks!
NI AE
Bobby Sun
(2,848 Views)
