Multifunction DAQ
Clocking hardware DO on PXI-6259
trying to output continous DigitalOutput using Counter Out as clock source. I can output multiple 32 bit words(an array of 30) at a rate of 500khz, but the digital output behaves like a finite output at any higher rate.
Outputs are burst once, then a static value ?
I think it has to do with buffer sizing, but can't find  a definitive answer.
Anybody enountyer this problem ?
(2,928 Views)
Perhaps a screenshot of your code can help visualize what the issue is...
(2,889 Views)
