Multifunction DAQ
Clear Task Error
i use DAQmx Create Channel.vi's to create 3 Channels: one of them as differential- so i have 2 (later maybe 3) tasks. Problem is, when i start my VI, i get error how some task resources are reserved, but i use Clear task?!?
Here is my application.
p.s.: Why not DAQmx Assistent Express? Because i need to change the sampling rate online.
Thanx in advance
Vedran D.
(3,030 Views)
Dear vedran,
You have to combine measurements of the same type into one task.
To understand better please have a look at the following links:
Why Do I Get Error -50103 When Using Multiple DAQ Assistant Express VIs?:
http://digital.ni.com/public.nsf/websearch/04BEDD9E9E91ED3486256D180048116D?OpenDocument
NI-DAQmx: Creating an Analog Input Task with Multiple Measurement Types:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=CA272F2D99585A8AE034080020E74861&p_node=200509&p_source=External
I slightly modified your VI (attached). Now it should work but with your card you're not able to change the sample rate of these measurements seperatly.
Best regards
(3,014 Views)
