Multifunction DAQ
Checking proper operation of I/Os using LabVIEW programatically
Hi Guys,
I have to build an application which is used to check all the I/Os (AI and DI) of the DAQ cards are working properly using LabVIEW. How do I do it??
Any help, suggestion or hint would be appreciated
Prashant
(2,921 Views)
Have you seen this? https://www.ni.com/en/support/downloads/software-products/download.daq-diagnostic-utility.html
The source code is not open. You can build an application, which calls this executable.
Alternately you need to compare readings with a reliable external source.
(2,900 Views)
Hey thanks for your valuable suggestion. I had not seen that link.. Regards, Prashant
(2,894 Views)
