Multifunction DAQ
Change attributes
How to change attributes in LabVIEW program which can be viewed in ETAS (INCA) software?
Message 1 of 20
(4,206 Views)
Please define your use of the word "attributes".
Message 2 of 20
(4,202 Views)
Better to ask ETAS about what to change in LabVIEW to reflect in their software.
https://www.etas.com/en/products/inca_software_products.php
Santhosh
Soliton Technologies
Message 3 of 20
(4,172 Views)
I have developed a LabVIEW program for temperature reading and it should be viewed by MDA tool in INCA software but at the same time, the attributes which we define should be able to modified based on user inputs.
How to use set and get attributes in program to define the values and change them while running the program?
Message 4 of 20
(4,135 Views)
Insufficient information as rarely a few of the users on this forum might be aware of your software "INCA". Please provide as much information as possible considering the users are LabVIEW developers and not familiar with the INCA software.
Santhosh
Message 5 of 20
(4,111 Views)
How to change attributes in LabVIEW program?? Define me with one example problem.
How to use set and get attributes???
Message 6 of 20
(4,081 Views)
I think there is a language barrier, attributes could mean a lot of things, what hardware are you using?
Unless you provide additional information, you may not get any useful guidance.
Santhosh
Message 7 of 20
(4,070 Views)
Thank you for your reply.
I am using DAQ hardware to detect temperature for each second using thermocouple.So how to change attributes in LabVIEW program and how to use set and get attributes??
Message 8 of 20
(4,058 Views)
Hello all
Since I am new to LabVIEW program so can someone help me out to solve the problem
How to connect and read DCU (Dosing Control Unit) variables using LabVIEW program?
Message 9 of 20
(3,990 Views)
You've not yet provided a concrete explanation of all your equipment involved (other than some keywords).
Generic guidance to control a NI DAQ instrument would be to use DAQmx APIs and this is a good tutorial, to begin with (skip the DAQ Assistant part) - https://www.ni.com/en-us/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-ha...
You can also find a lot of LabVIEW examples to control various types of DAQ tasks in the LabVIEW example finder (Help >> Find Examples...)
We are still not equipped with all information related to your equipment to guide you in a definitive direction.
Santhosh
Message 10 of 20
(3,985 Views)
