Multifunction DAQ
Cannot interface with simulated DAQmx
I am simulating a PCIe-6259 "Dev1" (generated long before issue) using
NI Max 2023 Q3
NI-DAQmx 21.3
LabVIEW 2021 SP1
In NI-Max I make DataNeighborhood>NI-DAQmx Tasks>MyVoltageTask an Analog input for  Dev1\ai0:31 and click run I get
DAQ Assistant Error (Repeats many times)
Error -200324 occurred at DAQ Assistant
Possible Reason(s):
NI-DAQmx is unable to communicate with the device. Make sure the device is present in and accessible to the system, and is not currently being reset.
Also hitting the reset, self test, self calibrate in NI-Max do not generate errors
Another trying to make a second device,  behaves differently
This problem shows similarly in LabVIEW :
I saw this thread https://forums.ni.com/t5/Multifunction-DAQ/Cannot-Simulate-Devices-in-MAX/td-p/2868798
but I do not find tools > Reset DAQmx data
(671 Views)
Accepted by topic author Onering20
https://forums.ni.com/t5/Multifunction-DAQ/Simulated-Device-Error-in-MAX/m-p/1691716/highlight/true#...
This post put me in the correct direction
NI Device Loader (nidevldu) was running, how ever I noticed that my Ni-RIO Server (nirioserver) was stopped and starting it fixed the issue immediately
(620 Views)
