Multifunction DAQ
Cannot configure USB-6009 properties
I recently installed a USB-6009. When I run the "Measurement & Automation" program utility, I can see the device under "Devices and Interfaces" but the properties button is grayed out when I select the device. Are there no properties available for the USB-6009? How do I configure the device to be differentially wired as opposed to single ended?
Kurt
(2,839 Views)
Hi Kurt
There are no properties that can be configured for the USB-6009 using this menu selection in Measurement and Automation Explorer (MAX).  The differential and single ended configurations are selected in the task itself.  So to select differential measurements create a task and ensure that terminal configuration is set to differential, and not RSE (reference single ended).
Chris_K
(2,820 Views)
