Multifunction DAQ
Can't read voltage from more than one channel (DAQmx read)
I have a SCB 68A connector from National Instruments and I want to read out the noise signal from it. So I used the example code (voltage1channel.png) provided by National Instruments (https://decibel.ni.com/content/docs/DOC-28502).
I got 5 mV which is a reasonable value (I measured the noise signal with an oscilloscope). Now I want to read out the noise signal from few channels. So I sightly changed the VI: voltage2channels.png (according to the documentation I need to create an array of channels and flatten them):
But now I read out approximately 200 mV on both channels (and one of them is the same as in the first VI). It doesn't make any sense.
What am I doing wrong?
I want the user to be able to choose the channels, so I can't just write "Dev1/ai0:4".
Message 1 of 1
(3,880 Views)
