Multifunction DAQ
Can anyone suggested which are accelerometer sensor compatible with USB 6001 ?
Can any guide me which are accelerometer Sensor which are compatible with  USB 6001 to measure the vibration ?
(2,427 Views)
What car should I suggest (or bicycle?)  ?  😉
What are your needs?
Acceleration range?
Frequency range?
Uncertainty?
Max sensor mass?
Temperature range?
(budged)
Or: What kind of vibration do want to measure?  Train vib in a building, ultrasound cracks in material?
For simple maschine monitoring I would suggest an accelerometer with an USB connector (hooks up as a soundcard) I think PCB made them...
If you want to play around  with your 6001 get a MEMS one with analog output for ~2$
Greetings from Germany
Henrik
LV since v3.1
(2,412 Views)
Hi Henrik,
             Thank You !!
                 To measure the vibration on free boundary condition of a plate .
Acceleration range upto 10 to 20 g
sensitivity 100mv/g
frequency range upto 1200 Hz
(2,382 Views)
