Multifunction DAQ
Can I use a reference trigger with a Linear Encoder Channel? (PCIe-6351)
I have a PCIe-6351 and I am trying to read the position from a linear encoder referenced to a digital trigger.  The digital trigger occurs in the middle of the motion that I am interested in, so I would like to capture a fixed number of pre-trigger and post-trigger encoder samples.  The graph below illustrates what I'm trying to get:
I have previously used the ReferenceTrigger with success on my AI channels to aquire analog data pre/post-trigger, but when I attempt to do the same with my LinearEncoderChannel I get "Error -200452: Specified property is not supported by the device or is not applicable to the task."
Am I doing something wrong?  Or is the ReferenceTrigger feature not available for the LinearEncoderChannel?  If it is not available, can you suggest an alternative method to acquire my pre-trigger position data?
I am developing in VB .NET 3.5.  My non-functioning code is as follows.  It throws the Error -200452 exception on the call to "myEncoderTask.Triggers.ReferenceTrigger.ConfigureDigitalEdgeTrigger":
    Public Sub RunTest()
        Dim myEncoderTask As Task = Nothing
        Dim myClockTask As Task = Nothing
        Try
            'Create new Tasks
            myEncoderTask = New Task()
            myClockTask = New Task()
            'Initialize Local Variables
            Dim PreSamples As Integer = 5000
            Dim TotalSamples As Integer = PreSamples + 20000
            'Create the linear encoder counter input channel
            myEncoderTask.CIChannels.CreateLinearEncoderChannel("PCIe6351/ctr0", "Encoder", CIEncoderDecodingType.X4, _
                                                         False, 0, CIEncoderZIndexPhase.AHighBHigh, 4, 0, _
                                                         CILinearEncoderUnits.Meters)
            'Create the clock output channel
            myClockTask.COChannels.CreatePulseChannelFrequency("PCIe6351/freqout", "Clock", COPulseFrequencyUnits.Hertz, _
                                                               COPulseIdleState.Low, 0, 6250, 0.5)
            'Configure Clock Timing Specs
            myEncoderTask.Timing.ConfigureSampleClock("/PCIE6351/PFI2", 6250, SampleClockActiveEdge.Rising, _
                                                      SampleQuantityMode.ContinuousSamples, TotalSamples)
            myClockTask.Timing.ConfigureImplicit(SampleQuantityMode.ContinuousSamples, TotalSamples)
            ' Configure Reference Trigger
            myEncoderTask.Triggers.ReferenceTrigger.ConfigureDigitalEdgeTrigger("/PCIE6351/PFI1", _
        DigitalEdgeReferenceTriggerEdge.Rising, PreSamples)
            ' Verify the Tasks
            myEncoderTask.Control(TaskAction.Verify)
            myClockTask.Control(TaskAction.Verify)
            myClockTask.Start()
            'Read the data
            Dim myReader As New CounterReader(myEncoderTask.Stream)
            Dim data() As Double = myReader.ReadMultiSampleDouble(TotalSamples)
        Catch ex As Exception
        Finally
            myEncoderTask.Dispose()
            myClockTask.Stop()
            myClockTask.Dispose()
        End Try
    End Sub
Any help would be greatly appreciated.
Eric
(3,896 Views)
Eric,
Unfortunately a referenced trigger cannot be used for counter tasks.  Would it be possible for you to change the point at which the trigger occurs?
James K.
(3,885 Views)
Hi James,
Thanks for your reply!
No, unfortunately I cannot change the point at which the trigger occurs.  That trigger is generated by a physical event that must occur in the flat "bottom" of my position trace.
My challenge is that this motion is a repetitive one. I'm trying to repeat the motion many times to generate statistics.  I was hoping to avoid capturing many iterations with one long trace and then manually cutting up the trace piecewise and aligning the time bases after the fact.
Can I synchronize my counter task to a digital channel task?  I'm thinking I might simultaneously log the trigger while capturing several motion iterations, then I could at least write some post-processing software to do all the subdividing and time base alignment for me.  Can I modify the "SyncAI_ReadDigChan" example from the documentation, using a counter task instead of an AI task?  Or will I run into similar problems as I did when I tried to use the referenced trigger with the counter task?
Do you have any other suggestions I might try?
Eric
(3,880 Views)
Eric,
You may be able to use a 'dummy task' to synchronize the counter and digital task, as in the following link:
https://decibel.ni.com/content/docs/DOC-11755
Also, what is your sampling rate/number of samples you are recording?
James K.
(3,870 Views)
